Ana içeriğe geç
Samsung SCH-A950 Speakers Replacement
Neye ihtiyacın var
  1. Samsung SCH-A950 Speakers Replacement, Battery: adım 1, 2 resimden 1. Samsung SCH-A950 Speakers Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
  2. Samsung SCH-A950 Speakers Replacement, Volume and Camera Buttons: adım 2, 1 resimden 1.
    • Remove the four Phillips #00 screws underneath the battery.
  3. Samsung SCH-A950 Speakers Replacement: adım 3, 2 resimden 1. Samsung SCH-A950 Speakers Replacement: adım 3, 2 resimden 2.
    • Pull open the earphone tab and the Trans Flash tab using your fingers.
  4. Samsung SCH-A950 Speakers Replacement: adım 4, 1 resimden 1.
    • Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
    • Slide the casing slightly forward towards the top of the phone to remove.
  5. Samsung SCH-A950 Speakers Replacement: adım 5, 3 resimden 1. Samsung SCH-A950 Speakers Replacement: adım 5, 3 resimden 2. Samsung SCH-A950 Speakers Replacement: adım 5, 3 resimden 3.
    • Using tweezers or your fingers, lift off buttons from logic board.
    • The buttons can be replaced if needed.
  6. Samsung SCH-A950 Speakers Replacement, Speakers: adım 6, 2 resimden 1. Samsung SCH-A950 Speakers Replacement, Speakers: adım 6, 2 resimden 2.
    • Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place.
    • Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
  7. Samsung SCH-A950 Speakers Replacement: adım 7, 1 resimden 1.
    • Using the tweezers, grasp the plastic connector that connects the speaker to the logic board and pull the connector off of the logic board.
  8. Samsung SCH-A950 Speakers Replacement: adım 8, 1 resimden 1.
    • Push the speaker out of the phone using the spudger.
  9. Samsung SCH-A950 Speakers Replacement: adım 9, 1 resimden 1.
    • Remove the speaker from the decorative housing by pulling on the wires.
    • The speaker can be replaced if needed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ashley Parry
20 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-5, Forte Winter 2010 Cal Poly, Team 11-5, Forte Winter 2010 üyesi
CPSU-FORTE-W10S11G5
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,755
