Ana içeriğe geç
Samsung SCH-U340 Lower Casing Replacement
Neye ihtiyacın var
  1. Samsung SCH-U340 Lower Casing Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Lower Casing Replacement: adım 2, 1 resimden 1.
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Lower Casing Replacement: adım 3, 1 resimden 1.
    • Set the battery aside.
  4. Samsung SCH-U340 Lower Casing Replacement, Lower Casing: adım 4, 1 resimden 1.
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  5. Samsung SCH-U340 Lower Casing Replacement: adım 5, 2 resimden 1. Samsung SCH-U340 Lower Casing Replacement: adım 5, 2 resimden 2.
    • Use a spudger to pry the back assembly off of the device.
Sonuç
Anish Sambamurthy
31 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-21, Maness Winter 2010 Cal Poly, Team 3-21, Maness Winter 2010 üyesi
CPSU-MANESS-W10S3G21
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 3,617
