Giriş
This guide will cover the removal of the Samsung SCH-U340 top casing.
Neye ihtiyacın var
Turn the cell phone so that the back side is facing you.
Press the upper indent and slide the back cover down.
The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs.
First, remove the plastic plugs covering the screws with a spudger.
Bir başkası bu kılavuzu tamamladı.
