Ana içeriğe geç
Samsung SCV-VLUUST50 Cover Replacement
Neye ihtiyacın var
  1. Samsung SCV-VLUUST50 Cover Replacement, Cover: adım 1, 3 resimden 1. Samsung SCV-VLUUST50 Cover Replacement, Cover: adım 1, 3 resimden 2. Samsung SCV-VLUUST50 Cover Replacement, Cover: adım 1, 3 resimden 3.
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Cover Replacement: adım 2, 3 resimden 1. Samsung SCV-VLUUST50 Cover Replacement: adım 2, 3 resimden 2. Samsung SCV-VLUUST50 Cover Replacement: adım 2, 3 resimden 3.
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Cover Replacement: adım 3, 1 resimden 1.
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Cover Replacement: adım 4, 2 resimden 1. Samsung SCV-VLUUST50 Cover Replacement: adım 4, 2 resimden 2.
    • Remove the front and back covers by pulling them straight apart.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 221
