Ana içeriğe geç
Samsung SCV-VLUUST50 Flash Bulb Replacement
Neye ihtiyacın var
  1. Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: adım 1, 3 resimden 1. Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: adım 1, 3 resimden 2. Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: adım 1, 3 resimden 3.
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Flash Bulb Replacement: adım 2, 3 resimden 1. Samsung SCV-VLUUST50 Flash Bulb Replacement: adım 2, 3 resimden 2. Samsung SCV-VLUUST50 Flash Bulb Replacement: adım 2, 3 resimden 3.
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Flash Bulb Replacement: adım 3, 1 resimden 1.
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Flash Bulb Replacement: adım 4, 2 resimden 1. Samsung SCV-VLUUST50 Flash Bulb Replacement: adım 4, 2 resimden 2.
    • Remove the front and back covers by pulling them straight apart.
  5. Samsung SCV-VLUUST50 Flash Bulb Replacement, Flash Bulb: adım 5, 2 resimden 1. Samsung SCV-VLUUST50 Flash Bulb Replacement, Flash Bulb: adım 5, 2 resimden 2.
    • Remove the screw securing the shutter button to the camera frame.
    • Lift the shutter button to remove it.
  6. Samsung SCV-VLUUST50 Flash Bulb Replacement: adım 6, 2 resimden 1. Samsung SCV-VLUUST50 Flash Bulb Replacement: adım 6, 2 resimden 2.
    • Remove the screws from the circuitry with a Phillips #000 driver.
    • Remove the screw connecting the flash housing to the camera frame with the same driver.
  7. Samsung SCV-VLUUST50 Flash Bulb Replacement: adım 7, 2 resimden 1. Samsung SCV-VLUUST50 Flash Bulb Replacement: adım 7, 2 resimden 2.
    • Pull the flash housing away from the camera frame.
    • Cut the wires connecting the flash module to the circuitry.
    • Connect the new flash module to the circuitry with a soldering iron and electrical solder.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 176
