Ana içeriğe geç
Samsung SCV-VLUUST50 Shutter Button Replacement
Neye ihtiyacın var
    1. Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: adım 1, 3 resimden 1. Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: adım 1, 3 resimden 2. Samsung SCV-VLUUST50 Shutter Button Replacement, Cover: adım 1, 3 resimden 3.
      • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
      • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung SCV-VLUUST50 Shutter Button Replacement: adım 2, 3 resimden 1. Samsung SCV-VLUUST50 Shutter Button Replacement: adım 2, 3 resimden 2. Samsung SCV-VLUUST50 Shutter Button Replacement: adım 2, 3 resimden 3.
      • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
      • Remove the corner panel by applying pressure away from the shutter button.
      • The memory card cover will come off with the corner panel.
      • Remove the top panel by applying gentle pressure away from the shutter button.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung SCV-VLUUST50 Shutter Button Replacement: adım 3, 1 resimden 1.
      • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung SCV-VLUUST50 Shutter Button Replacement: adım 4, 2 resimden 1. Samsung SCV-VLUUST50 Shutter Button Replacement: adım 4, 2 resimden 2.
      • Remove the front and back covers by pulling them straight apart.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: adım 5, 3 resimden 1. Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: adım 5, 3 resimden 2. Samsung SCV-VLUUST50 Shutter Button Replacement, Shutter Button: adım 5, 3 resimden 3.
      • Remove the screw below the shutter button with a Phillips #000 screw driver.
      • Once the screw is removed the shutter button should easily come off, and you can replace it with the new button.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 569
