Ana içeriğe geç
Samsung SGH A707 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung SGH A707 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Press on the markings on the cover and pull it down to reveal the battery.
  2. Samsung SGH A707 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use your fingers to pull the battery out of its position. You may also flip the phone and the battery will fall out.
  3. Samsung SGH A707 Motherboard Replacement: adım 3, 1 resimden 1.
    • Here is the phone without the battery.
  4. Samsung SGH A707 Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Samsung SGH A707 Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
  5. Samsung SGH A707 Motherboard Replacement: adım 5, 1 resimden 1.
    • Use the prying tool the pry off the phone's plastic frame.
  6. Samsung SGH A707 Motherboard Replacement: adım 6, 3 resimden 1. Samsung SGH A707 Motherboard Replacement: adım 6, 3 resimden 2. Samsung SGH A707 Motherboard Replacement: adım 6, 3 resimden 3.
    • Use the prying tool to disconnect the rectangular connector.
  7. Samsung SGH A707 Motherboard Replacement: adım 7, 1 resimden 1.
    • Use the prying tool to disconnect the small connector.
  8. Samsung SGH A707 Motherboard Replacement: adım 8, 1 resimden 1.
    • Gently pull off the circuit board.
  9. Samsung SGH A707 Motherboard Replacement: adım 9, 1 resimden 1.
    • Here is the phone without the logic board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
yfm
25 İtibar
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 732
