Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Samsung SGH-A117 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Samsung SGH-A117: Breakdown and Reassembly, Samsumg SGH-A117: adım 1, 1 resimden 1.
    • This is the Samsung SGH-A117.
  2. Samsung SGH-A117: Breakdown and Reassembly, Backside of the cellphone: adım 2, 1 resimden 1.
    • This is the back view following the removal of the back cover and battery.
  3. Samsung SGH-A117: Breakdown and Reassembly, Removing Screws: adım 3, 1 resimden 1.
    • Use a screwdriver to remove screws around the frame.
    • Use a PH00 size screw to operate this step.
    • The screws are extremely small. It is recommended to have a small container to keep track of the screws.
  4. Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: adım 4, 2 resimden 1. Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: adım 4, 2 resimden 2.
    • Insert the spudger under the back cover at the marked locations and gently lift to remove the back cover.
    • The end of the phone closest to the hinge will require additional force to lift.
    • Be careful not to bend the cover during the removal process.
  5. Samsung SGH-A117: Breakdown and Reassembly, Separate Circuit Connector from Logic Board: adım 5, 1 resimden 1.
    • Use a spudger to gently lift the circuit connector from the logic board.
    • Be careful not to remove the circuit connector from the phone.
  6. Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: adım 6, 2 resimden 1. Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: adım 6, 2 resimden 2.
    • Use a spudger to lift the logic board and separate it from the main body of the phone.
    • It is recommended to lift from the bottom part of the logic board as shown in the picture.
    • Be careful not to lose the volume button, which is loosely attached to the logic board.
  7. Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: adım 7, 2 resimden 1. Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: adım 7, 2 resimden 2.
    • Gently push the keyboard from the case as shown in the picture.
  8. Samsung SGH-A117: Breakdown and Reassembly, Layout of Disassembled Device: adım 8, 1 resimden 1.
    • 1 Case
    • 1 Keyboard
    • 1 Logic Board
    • 1 Volume Control
    • 1 Back Cover
    • 5 Screws
Justin
150 İtibar
2 adet Kılavuz yazıldı
Ekip
Aristotle Aristotle üyesi
Community
5 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 820
