Bu Teardown'da Kullanılan Aletler
Giriş
Samsung SGH-A117 is a basic flip phone. This guide will describe the steps required for disassembling and reassembling the phone.
This is the back view following the removal of the back cover and battery.
Insert the spudger under the back cover at the marked locations and gently lift to remove the back cover.
The end of the phone closest to the hinge will require additional force to lift.
Use a spudger to gently lift the circuit connector from the logic board.
Use a spudger to lift the logic board and separate it from the main body of the phone.
1 Case
1 Keyboard
1 Logic Board
1 Volume Control
1 Back Cover
5 Screws
