Ana içeriğe geç
Samsung SGH-A237 Camera Replacement
  1. Samsung SGH-A237 Camera Replacement, Camera: adım 1, 1 resimden 1.
    • Place the phone on a flat surface with the camera facing upwards.
    • Have a designated space to keep track of each small part.
  2. Samsung SGH-A237 Camera Replacement: adım 2, 1 resimden 1.
    • Open the phone.
    • Remove the two rubber soft screw covers below the viewing screen using a pair of tweezers.
  3. Samsung SGH-A237 Camera Replacement: adım 3, 1 resimden 1.
    • Loosen the screws under the soft screw covers using a Phillips #00 screwdriver.
  4. Samsung SGH-A237 Camera Replacement: adım 4, 3 resimden 1. Samsung SGH-A237 Camera Replacement: adım 4, 3 resimden 2. Samsung SGH-A237 Camera Replacement: adım 4, 3 resimden 3.
    • Failure to utilize the specified tool may cause damage to the device.
    • Locate the black cover plate on the back side of the viewing screen. It will show the AT&T and Samsung logos.
    • Look on the right side of the phone for the crease in between the black back cover and the front silver cover of the viewing screen.
    • Pry the cover plate off using a plastic opening tool.
  5. Samsung SGH-A237 Camera Replacement: adım 5, 2 resimden 1. Samsung SGH-A237 Camera Replacement: adım 5, 2 resimden 2.
    • Identify the metal bracket that covers the internal body.
    • Identify the metal tabs surrounding the metal bracket mentioned in the previous step.
    • Remove the metal bracket using a small pick or a Phillips #00 screwdriver.
    • Close the phone.
  6. Samsung SGH-A237 Camera Replacement: adım 6, 1 resimden 1.
    • Find the camera on the upper part of the phone. It will be displayed as a small black circle.
    • Follow the copper ribbon connected to the camera downward to the black connection port.
  7. Samsung SGH-A237 Camera Replacement: adım 7, 2 resimden 1. Samsung SGH-A237 Camera Replacement: adım 7, 2 resimden 2.
    • Failure to utilize the specified tool in the proper way may cause damage to the device.
    • Pry up the black connector using a pick. This should lock the black connector into an upward position, which will release the copper ribbon connected to the phone's camera.
  8. Samsung SGH-A237 Camera Replacement: adım 8, 2 resimden 1. Samsung SGH-A237 Camera Replacement: adım 8, 2 resimden 2.
    • Gently grasp the copper ribbon attached to the camera using a pair of tweezers.
    • Gently pull copper ribbon towards the camera. This should pull the copper ribbon out completely.
  9. Samsung SGH-A237 Camera Replacement: adım 9, 1 resimden 1.
    • Remove the camera.
Sonuç
Jonathon
10 İtibar
1 Kılavuz yazıldı
Ohio State, Team 1-4, Mccook Fall 2014 Ohio State, Team 1-4, Mccook Fall 2014 üyesi
OSU-MCCOOK-F14S1G4
3 Üyeler
2 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 301
