Ana içeriğe geç
Samsung SGH-A237 Keypad Replacement
Neye ihtiyacın var
  1. Samsung SGH-A237 Keypad Replacement, Keypad: adım 1, 2 resimden 1. Samsung SGH-A237 Keypad Replacement, Keypad: adım 1, 2 resimden 2.
    • Place phone face down so battery cover is showing.
  2. Samsung SGH-A237 Keypad Replacement: adım 2, 2 resimden 1. Samsung SGH-A237 Keypad Replacement: adım 2, 2 resimden 2.
    • Use thumb to push the cover down and off.
    • Lift battery cover off the device.
  3. Samsung SGH-A237 Keypad Replacement: adım 3, 2 resimden 1. Samsung SGH-A237 Keypad Replacement: adım 3, 2 resimden 2.
    • Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Keypad Replacement: adım 4, 3 resimden 1. Samsung SGH-A237 Keypad Replacement: adım 4, 3 resimden 2. Samsung SGH-A237 Keypad Replacement: adım 4, 3 resimden 3.
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Some force must be applied, and the back cover should come off.
  5. Samsung SGH-A237 Keypad Replacement: adım 5, 1 resimden 1.
    • Detach the tab from the logic board shown by using the Ipod Opening Tool
  6. Samsung SGH-A237 Keypad Replacement: adım 6, 2 resimden 1. Samsung SGH-A237 Keypad Replacement: adım 6, 2 resimden 2.
    • Use the Ipod Opening Tool to lift the green logic board carefully.
    • Remove the logic board from the device.
  7. Samsung SGH-A237 Keypad Replacement: adım 7, 1 resimden 1.
    • The keypad should peel off the logic board with a gentle pull.
    • Use a clean, soft, cotton cloth to gently remove any debris or liquid that may be located on the pad or logic board interface.
Sonuç
Shawn
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-81, Johann Spring 2010 Cal Poly, Team 29-81, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G81
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
This was very helpful. There is no other place I could find a guide to take this phone apart. Even Samsung chat was unable to help!! Thanks very much!
Steve - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 12
Her zaman: 2,314
