Ana içeriğe geç
Samsung SGH-E317 Camera Replacement
Neye ihtiyacın var
  1. Samsung SGH-E317 Camera Replacement, Camera: adım 1, 2 resimden 1. Samsung SGH-E317 Camera Replacement, Camera: adım 1, 2 resimden 2.
    • Remove the plastic coverings at the base of the LCD screen using your fingers.
  2. Samsung SGH-E317 Camera Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to remove the two 4.5mm screws located underneath the plastic coverings.
    • You may want to use tweezers to remove the loosened screws.
  3. Samsung SGH-E317 Camera Replacement: adım 3, 1 resimden 1.
    • Wedge the plastic opening tool under the crevice on the inner surface of the phone screen.
    • Gently pry the top panel off around the entire frame.
  4. Samsung SGH-E317 Camera Replacement: adım 4, 2 resimden 1. Samsung SGH-E317 Camera Replacement: adım 4, 2 resimden 2.
    • Make sure that the top panel is completely separated from the LCD display around the entire perimeter.
  5. Samsung SGH-E317 Camera Replacement: adım 5, 1 resimden 1.
    • Take the top panel off of the phone.
  6. Samsung SGH-E317 Camera Replacement: adım 6, 2 resimden 1. Samsung SGH-E317 Camera Replacement: adım 6, 2 resimden 2.
    • Use the wedge to detach the connecting wire panel from the LCD display system.
    • Be gentle when dethatching this wire to prevent damaging surrounding components.
  7. Samsung SGH-E317 Camera Replacement: adım 7, 2 resimden 1. Samsung SGH-E317 Camera Replacement: adım 7, 2 resimden 2.
    • Use the tweezers to remove the camera from the cellphone casing.
Sonuç
Michael Strange
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-23, Maness Winter 2011 Cal Poly, Team 11-23, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G23
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 1,503
