Giriş
The motherboard is the main electronic "heart" of the phone. Only proceed with this replacement if you have tried all other options to no avail.
  1. Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. Unscrew the four 4.5mm screws located on the back plate.
    • Unscrew the four 4.5mm screws located on the back plate.
    • Remove the rubber screw cover using your fingernail.
    • Unscrew the 4.5mm screw located underneath the rubber cover.
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
    • With the back panel removed, the motherboard should be fully exposed.
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
Sonuç
Chris Dimler
124 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 11-23, Maness Winter 2011 Cal Poly, Team 11-23, Maness Winter 2011 üyesi
CPSU-MANESS-W11S11G23
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 1,264
