Ana içeriğe geç
Samsung SGH-T639 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung SGH-T639 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. Samsung SGH-T639 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use button to remove battery from the phone.
  3. Samsung SGH-T639 Motherboard Replacement, SIM Card: adım 3, 3 resimden 1. Samsung SGH-T639 Motherboard Replacement, SIM Card: adım 3, 3 resimden 2. Samsung SGH-T639 Motherboard Replacement, SIM Card: adım 3, 3 resimden 3.
    • Locate SIM card
    • Slide SIM card down and gently pull out of the card slot
  4. Samsung SGH-T639 Motherboard Replacement, Motherboard: adım 4, 3 resimden 1. Samsung SGH-T639 Motherboard Replacement, Motherboard: adım 4, 3 resimden 2. Samsung SGH-T639 Motherboard Replacement, Motherboard: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Locate the six (4mm) screws on the back casing of the phone.
    • Unscrew each one using a phillips head #000 screwdriver.
    • Place screws on magnetic mat.
  5. Samsung SGH-T639 Motherboard Replacement: adım 5, 3 resimden 1. Samsung SGH-T639 Motherboard Replacement: adım 5, 3 resimden 2. Samsung SGH-T639 Motherboard Replacement: adım 5, 3 resimden 3.
    • Starting at the top of the phone, carefully insert plastic opening device into the seam.
    • Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
    • Note: Some force must be exerted. Be careful when taking off panel. Go slow.
    • Note: The volume button may separate from the case, this is normal. It is not broken.
  6. Samsung SGH-T639 Motherboard Replacement: adım 6, 3 resimden 1. Samsung SGH-T639 Motherboard Replacement: adım 6, 3 resimden 2. Samsung SGH-T639 Motherboard Replacement: adım 6, 3 resimden 3.
    • Locate the connection point of black wire running from the microphone to the motherboard.
    • Carefully disconnect the gold connector from the motherboard using tweezers.
  7. Samsung SGH-T639 Motherboard Replacement: adım 7, 3 resimden 1. Samsung SGH-T639 Motherboard Replacement: adım 7, 3 resimden 2. Samsung SGH-T639 Motherboard Replacement: adım 7, 3 resimden 3.
    • Locate the red connector at the top of the motherboard.
    • Carefully lift and remove the connector from the motherboard using tweezers.
  8. Samsung SGH-T639 Motherboard Replacement: adım 8, 3 resimden 1. Samsung SGH-T639 Motherboard Replacement: adım 8, 3 resimden 2. Samsung SGH-T639 Motherboard Replacement: adım 8, 3 resimden 3.
    • Locate the gold connector that connects the screen to the motherboard.
    • Carefully disconnect the connector from the motherboard using tweezers.
  9. Samsung SGH-T639 Motherboard Replacement: adım 9, 3 resimden 1. Samsung SGH-T639 Motherboard Replacement: adım 9, 3 resimden 2. Samsung SGH-T639 Motherboard Replacement: adım 9, 3 resimden 3.
    • Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool.
    • Lift the motherboard from the cell phone.
  10. Samsung SGH-T639 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard from the cell phone.
Sonuç
Yi Ren
801 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-4, Benson Spring 2014 Clemson, Team 1-4, Benson Spring 2014 üyesi
CLEM-BENSON-S14S1G4
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 290
