Giriş
Replacing the earpiece speaker
Neye ihtiyacın var
Rotate the phone onto its front side so that the LCD screen is facing away from you.
Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
Put aside the back panel. You will only be working with the front panel from here on.
Bir başkası bu kılavuzu tamamladı.
