Ana içeriğe geç
Samsung SGH-X105 Earpiece Speaker Replacement
Neye ihtiyacın var
  1. Samsung SGH-X105 Earpiece Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Samsung SGH-X105 Earpiece Speaker Replacement: adım 2, 3 resimden 1. Samsung SGH-X105 Earpiece Speaker Replacement: adım 2, 3 resimden 2. Samsung SGH-X105 Earpiece Speaker Replacement: adım 2, 3 resimden 3.
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Samsung SGH-X105 Earpiece Speaker Replacement, Front & Back Panels: adım 3, 1 resimden 1.
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Samsung SGH-X105 Earpiece Speaker Replacement: adım 4, 3 resimden 1. Samsung SGH-X105 Earpiece Speaker Replacement: adım 4, 3 resimden 2. Samsung SGH-X105 Earpiece Speaker Replacement: adım 4, 3 resimden 3.
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Samsung SGH-X105 Earpiece Speaker Replacement: adım 5, 2 resimden 1. Samsung SGH-X105 Earpiece Speaker Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Samsung SGH-X105 Earpiece Speaker Replacement, Earpiece Speaker: adım 6, 1 resimden 1.
    • Put aside the back panel. You will only be working with the front panel from here on.
  7. Samsung SGH-X105 Earpiece Speaker Replacement: adım 7, 3 resimden 1. Samsung SGH-X105 Earpiece Speaker Replacement: adım 7, 3 resimden 2. Samsung SGH-X105 Earpiece Speaker Replacement: adım 7, 3 resimden 3.
    • Using a SL 1.5 flathead screwdriver (or any small prying tool), pry the speaker from the plastic front cover.
    • The earpiece speaker is magnetic so you can use a magnet to remove the earpiece speaker from the plastic front cover once loosened.
    • You can apply your own adhesive to secure your replaced speaker if desired during reassembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Lao
16 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 28-29, Regan Spring 2010 Cal Poly, Team 28-29, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G29
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Where can I get a replacement speaker?
NickyPhils - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 1,953
