Ana içeriğe geç
Samsung SGH-X105 Keypad Replacement
Neye ihtiyacın var
    1. Samsung SGH-X105 Keypad Replacement, Battery: adım 1, 1 resimden 1.
      • Rotate the phone onto its front side so that the LCD screen is facing away from you.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung SGH-X105 Keypad Replacement: adım 2, 3 resimden 1. Samsung SGH-X105 Keypad Replacement: adım 2, 3 resimden 2. Samsung SGH-X105 Keypad Replacement: adım 2, 3 resimden 3.
      • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung SGH-X105 Keypad Replacement, Front & Back Panels: adım 3, 1 resimden 1.
      • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
      • Complete removal of screws may not be necessary.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung SGH-X105 Keypad Replacement: adım 4, 3 resimden 1. Samsung SGH-X105 Keypad Replacement: adım 4, 3 resimden 2. Samsung SGH-X105 Keypad Replacement: adım 4, 3 resimden 3.
      • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
      • Volume control button will be unsecured and may fall out as soon as the panels are separated.
      • Gentle force may be required to separate the panels at the top latch.
      • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung SGH-X105 Keypad Replacement: adım 5, 2 resimden 1. Samsung SGH-X105 Keypad Replacement: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung SGH-X105 Keypad Replacement, Keypad: adım 6, 1 resimden 1.
      • Put aside the back panel. You will only be working with the front panel from here on.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung SGH-X105 Keypad Replacement: adım 7, 2 resimden 1. Samsung SGH-X105 Keypad Replacement: adım 7, 2 resimden 2.
      • Take out the key pad by pressing the keys on the face of the phone and pulling the rubber keypad from the other side.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Alex Martinez
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 28-29, Regan Spring 2010 Cal Poly, Team 28-29, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G29
4 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 1,597
