Ana içeriğe geç
Samsung SGH-X495 Headphone Jack Replacement
Neye ihtiyacın var
  1. Samsung SGH-X495 Headphone Jack Replacement, Backplate: adım 1, 1 resimden 1.
    • Remove the 4 (4.7mm) philips head screws.
  2. Samsung SGH-X495 Headphone Jack Replacement: adım 2, 1 resimden 1.
    • Unplug the rubber charger outlet cover.
  3. Samsung SGH-X495 Headphone Jack Replacement: adım 3, 1 resimden 1.
    • Unplug the rubber headset jack cover.
  4. Samsung SGH-X495 Headphone Jack Replacement: adım 4, 2 resimden 1. Samsung SGH-X495 Headphone Jack Replacement: adım 4, 2 resimden 2.
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
  5. Samsung SGH-X495 Headphone Jack Replacement: adım 5, 2 resimden 1. Samsung SGH-X495 Headphone Jack Replacement: adım 5, 2 resimden 2.
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
  6. Samsung SGH-X495 Headphone Jack Replacement, Motherboard: adım 6, 1 resimden 1.
    • Remove the ribbon wires connecting to the screen using the pry tool.
  7. Samsung SGH-X495 Headphone Jack Replacement: adım 7, 1 resimden 1.
    • 2 tabs hold the motherboard in place.
    • Release the labeled tabs with the pry tool from the location shown.
  8. Samsung SGH-X495 Headphone Jack Replacement: adım 8, 1 resimden 1.
    • Separate the motherboard from the phone.
  9. Samsung SGH-X495 Headphone Jack Replacement, Headphone Jack: adım 9, 1 resimden 1.
    • Solder connections can be accessed to replace head phone jack.
Sonuç
Matthew Hove
1.031 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-40, Regan Winter 2011 Cal Poly, Team 3-40, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G40
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,726
