Ana içeriğe geç
Samsung SPEX SCH-R210 Keypad Replacement
Neye ihtiyacın var
  1. Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: adım 1, 3 resimden 1. Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: adım 1, 3 resimden 2. Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: adım 1, 3 resimden 3.
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung SPEX SCH-R210 Keypad Replacement, Battery: adım 2, 1 resimden 1.
    • Locate the access notch at the end of the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung SPEX SCH-R210 Keypad Replacement: adım 3, 1 resimden 1.
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung SPEX SCH-R210 Keypad Replacement, Keypad: adım 4, 2 resimden 1. Samsung SPEX SCH-R210 Keypad Replacement, Keypad: adım 4, 2 resimden 2.
    • Remove the four 4.8 mm screws from the midframe using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung SPEX SCH-R210 Keypad Replacement: adım 5, 1 resimden 1.
    • Remove the headphone cover from the left side of the midframe.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung SPEX SCH-R210 Keypad Replacement: adım 6, 1 resimden 1.
    • Remove the volume cover from the right side of the midframe.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung SPEX SCH-R210 Keypad Replacement: adım 7, 1 resimden 1.
    • Use your hands to separate the midframe from the rest of the phone.
    • This may take a little effort to remove.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung SPEX SCH-R210 Keypad Replacement: adım 8, 1 resimden 1.
    • Use a 1.5 mm hex screwdriver to remove the three 2.4 mm screws around the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung SPEX SCH-R210 Keypad Replacement: adım 9, 1 resimden 1.
    • Lift the metal plate off of the motherboard and set it aside.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung SPEX SCH-R210 Keypad Replacement: adım 10, 2 resimden 1. Samsung SPEX SCH-R210 Keypad Replacement: adım 10, 2 resimden 2.
    • Push on the white plastic tabs and the keypad at the same time to remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung SPEX SCH-R210 Keypad Replacement: adım 11, 2 resimden 1. Samsung SPEX SCH-R210 Keypad Replacement: adım 11, 2 resimden 2.
    • Turn the phone over to its front side.
    • Apply pressure on the keypad.
    • The keypad will come out easily.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Susan
331 İtibar
3 adet Kılavuz yazıldı
Ekip
WRI115, Team 1-4, Ruszkiewicz Spring 2013 WRI115, Team 1-4, Ruszkiewicz Spring 2013 üyesi
WRI115-RUSZKIEWICZ-S13S1G4
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 648
