Ana içeriğe geç
Samsung SPEX SCH-R210 Speaker Replacement
Neye ihtiyacın var
  1. Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: adım 1, 3 resimden 1. Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: adım 1, 3 resimden 2. Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: adım 1, 3 resimden 3.
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung SPEX SCH-R210 Speaker Replacement, Battery: adım 2, 1 resimden 1.
    • Locate the access notch at the end of the battery compartment.
  3. Samsung SPEX SCH-R210 Speaker Replacement: adım 3, 1 resimden 1.
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
  4. Samsung SPEX SCH-R210 Speaker Replacement, Speaker: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew the four 3/16" screws holding the black plastic cover of the phone in place.
  5. Samsung SPEX SCH-R210 Speaker Replacement: adım 5, 2 resimden 1. Samsung SPEX SCH-R210 Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the small, black headphone cover from the left side of the phone by gently pulling it off.
    • Remove the small, black volume cover from the right side of the phone by gentle pulling it off.
  6. Samsung SPEX SCH-R210 Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the black plastic cover from the back of the phone by slowly pulling it off. This may take a little effort.
  7. Samsung SPEX SCH-R210 Speaker Replacement: adım 7, 1 resimden 1.
    • Once the plastic cover is removed, turn the cover over so that the insides are visible.
    • Using your fingernail, pry out the small, grey, circular speaker from the cover.
  8. Samsung SPEX SCH-R210 Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the old speaker, discard it and replace it with a new speaker.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Susan
331 İtibar
3 adet Kılavuz yazıldı
Ekip
WRI115, Team 1-4, Ruszkiewicz Spring 2013 WRI115, Team 1-4, Ruszkiewicz Spring 2013 üyesi
WRI115-RUSZKIEWICZ-S13S1G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 448
