Ana içeriğe geç
Samsung SPEX SCH-R210 antenna Replacement
Neye ihtiyacın var
  1. Samsung SPEX SCH-R210 antenna Replacement, Back Cover: adım 1, 3 resimden 1. Samsung SPEX SCH-R210 antenna Replacement, Back Cover: adım 1, 3 resimden 2. Samsung SPEX SCH-R210 antenna Replacement, Back Cover: adım 1, 3 resimden 3.
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung SPEX SCH-R210 antenna Replacement, Battery: adım 2, 1 resimden 1.
    • Locate the access notch at the end of the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung SPEX SCH-R210 antenna Replacement: adım 3, 1 resimden 1.
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung SPEX SCH-R210 antenna Replacement, Antenna: adım 4, 2 resimden 1. Samsung SPEX SCH-R210 antenna Replacement, Antenna: adım 4, 2 resimden 2.
    • After removing the battery, unscrew the 4 3/16" screws on the black plastic cover with the Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung SPEX SCH-R210 antenna Replacement: adım 5, 2 resimden 1. Samsung SPEX SCH-R210 antenna Replacement: adım 5, 2 resimden 2.
    • Remove the headphone cover from the left side and the volume cover from the right side of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung SPEX SCH-R210 antenna Replacement: adım 6, 1 resimden 1.
    • Remove the black plastic cover from the back of the phone. This may take a little effort to remove.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung SPEX SCH-R210 antenna Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • The antenna is located on the opposite side of the black plastic cover. Use the tweezers to remove the antenna.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung SPEX SCH-R210 antenna Replacement: adım 8, 1 resimden 1.
    • The gray rubber antenna cover will need to come out as well. Use the tweezers to remove the gray cover.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung SPEX SCH-R210 antenna Replacement: adım 9, 1 resimden 1.
    • Replace with a new antenna.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Susan
331 İtibar
3 adet Kılavuz yazıldı
Ekip
WRI115, Team 1-4, Ruszkiewicz Spring 2013 WRI115, Team 1-4, Ruszkiewicz Spring 2013 üyesi
WRI115-RUSZKIEWICZ-S13S1G4
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 550
