Ana içeriğe geç
Samsung SPH-A500 Front LCD Display Replacement
Neye ihtiyacın var
    1. Samsung SPH-A500 Front LCD Display Replacement, Front LCD Display: adım 1, 1 resimden 1.
      • Flip open the phone, remove the two rubber covers under the LCD screen.
      • Remove the two screws using a small Philips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung SPH-A500 Front LCD Display Replacement: adım 2, 1 resimden 1.
      • Using a plastic opening tool, pry open the back cover of the LCD screen.
      • Note: Some force may be required.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung SPH-A500 Front LCD Display Replacement: adım 3, 1 resimden 1.
      • Completely separate the back cover from the rest of the phone.
      • Close the phone.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung SPH-A500 Front LCD Display Replacement: adım 4, 1 resimden 1.
      • The LCD screen is big, rectangular screen in the center of the logic board.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung SPH-A500 Front LCD Display Replacement: adım 5, 1 resimden 1.
      • Remove the glue and black tape that is attached to the LCD screen
      FixBot'a Sor
      Yorum Ekle
    6. Samsung SPH-A500 Front LCD Display Replacement: adım 6, 1 resimden 1.
      • Remove Broken LCD Screen.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung SPH-A500 Front LCD Display Replacement: adım 7, 1 resimden 1.
      • Attach the New LCD Screen, with wire point up and out to the black connector.
      • Note: Super Glue may be required to permanently attach LCD to the black connector
      FixBot'a Sor
      Yorum Ekle
Sonuç
Derek Panger
21 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-100, Johann Spring 2010 Cal Poly, Team 18-100, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G100
4 Üyeler
35 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 39
Her zaman: 2,905
