Ana içeriğe geç
Samsung SPH-A500 Logic Board Replacement
Neye ihtiyacın var
  1. Samsung SPH-A500 Logic Board Replacement, Logic Board: adım 1, 1 resimden 1.
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Samsung SPH-A500 Logic Board Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Samsung SPH-A500 Logic Board Replacement: adım 3, 1 resimden 1.
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Samsung SPH-A500 Logic Board Replacement: adım 4, 1 resimden 1.
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  5. Samsung SPH-A500 Logic Board Replacement: adım 5, 1 resimden 1.
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Do not completely pull out the circuit board.
  6. Samsung SPH-A500 Logic Board Replacement: adım 6, 1 resimden 1.
    • Look for the clip at the top right corner of the logic board.
  7. Samsung SPH-A500 Logic Board Replacement: adım 7, 1 resimden 1.
    • Remove the clip from the logic board.
  8. Samsung SPH-A500 Logic Board Replacement: adım 8, 1 resimden 1.
    • Remove the logic board.
    • Replace the broken logic board with a new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick Dominikovic
139 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-100, Johann Spring 2010 Cal Poly, Team 18-100, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G100
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,033
