Ana içeriğe geç
Samsung SPH-A500 Speaker Replacement
Neye ihtiyacın var
  1. Samsung SPH-A500 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Speaker Replacement: adım 2, 1 resimden 1.
    • Using an Ipod opening tool or your finger nails, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Speaker Replacement: adım 3, 1 resimden 1.
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Speaker Replacement: adım 4, 1 resimden 1.
    • The speaker is covered with silver tape on the bottom of the logic board.
  5. Samsung SPH-A500 Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the silver tape that is covering the speaker.
  6. Samsung SPH-A500 Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the speaker.
    • Note: In order to completely remove the speaker you must disconnect the wires, which will require a soldering iron to reattach the new speaker.
  7. Samsung SPH-A500 Speaker Replacement: adım 7, 1 resimden 1.
    • Attach the new speaker using a soldering iron.
    • Put the speaker back to it's original position and place the silver tape over it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick Dominikovic
139 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-100, Johann Spring 2010 Cal Poly, Team 18-100, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G100
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 2,336
