Ana içeriğe geç
Samsung SPH-A660 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung SPH-A660 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Samsung SPH-A660 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the phone over so that it is face down.
  2. Samsung SPH-A660 Motherboard Replacement: adım 2, 3 resimden 1. Samsung SPH-A660 Motherboard Replacement: adım 2, 3 resimden 2. Samsung SPH-A660 Motherboard Replacement: adım 2, 3 resimden 3.
    • To remove the battery, push up with your finger on the tab located on the top center of the back of the phone.
    • Next, pull the battery off the back of the phone.
  3. Samsung SPH-A660 Motherboard Replacement, Motherboard: adım 3, 2 resimden 1. Samsung SPH-A660 Motherboard Replacement, Motherboard: adım 3, 2 resimden 2.
    • Once the battery pack is removed from the phone, remove the five indicated screws with a size #00 Philips screwdriver.
    • Bend back the antenna to access the indicated left middle screw in order to unscrew it.
    • Do not forget to unscrew the indicated screw on the top left corner of the phone. It will be difficult in further steps to take the phone apart if this screw is left in.
  4. Samsung SPH-A660 Motherboard Replacement: adım 4, 3 resimden 1. Samsung SPH-A660 Motherboard Replacement: adım 4, 3 resimden 2. Samsung SPH-A660 Motherboard Replacement: adım 4, 3 resimden 3.
    • Place the phone on its side.
    • Insert the small plastic opening tool into the slot that runs along the side of the phone.
    • Slowly pry open the phone by working your way around its edges with the opening tool.
    • There are tabs that run the entire length of the phone which hold the phone together. You may need a significant amount of force to pry the phone apart.
    • During this step, the side volume key may fall out; this is okay.
  5. Samsung SPH-A660 Motherboard Replacement: adım 5, 1 resimden 1.
    • Carefully lift the highlighted connector between the logic board and the screen by using either your fingers or a plastic opening tool as shown in the picture.
  6. Samsung SPH-A660 Motherboard Replacement: adım 6, 3 resimden 1. Samsung SPH-A660 Motherboard Replacement: adım 6, 3 resimden 2. Samsung SPH-A660 Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove the green logic board from the phone by gently lifting it up with the plastic opening tool. Be cautious to not break the logic board.
    • The keypad may fall out, this is okay. Set it aside.
Sonuç
Kyle Cole
6 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-26, Maness Winter 2010 Cal Poly, Team 13-26, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G26
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 27
Her zaman: 2,354
