Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Samsung SPH-M360 Keyboard Replacement
Neye ihtiyacın var
  1. Samsung SPH-M360 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Samsung SPH-M360 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Samsung SPH-M360 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Keyboard Replacement: adım 2, 3 resimden 1. Samsung SPH-M360 Keyboard Replacement: adım 2, 3 resimden 2. Samsung SPH-M360 Keyboard Replacement: adım 2, 3 resimden 3.
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
  3. Samsung SPH-M360 Keyboard Replacement, Casing: adım 3, 1 resimden 1.
    • Remove the four screws on the corners of the casing.
    • The volume and camera buttons may fall out
  4. Samsung SPH-M360 Keyboard Replacement: adım 4, 2 resimden 1. Samsung SPH-M360 Keyboard Replacement: adım 4, 2 resimden 2.
    • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
    • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
  5. Samsung SPH-M360 Keyboard Replacement: adım 5, 2 resimden 1. Samsung SPH-M360 Keyboard Replacement: adım 5, 2 resimden 2.
    • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
    • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
  6. Samsung SPH-M360 Keyboard Replacement, Keyboard: adım 6, 1 resimden 1.
    • Flip open the phone so that the text on the keyboard is visible.
    • Push from the text side until the keyboard comes completely out of the phone casing.
Sonuç
Hunter Parker
475 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 72
