Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Parçalar
Hiçbir parça belirtilmedi.
  1. Locate the arrow on the panel of the rear side of the phone. Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow. Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Place finger inside the small semi-spherical slot near the top of the battery. Lightly pull the battery away from the phone. This should not require much effort. Lightly pull the battery away from the phone. This should not require much effort.
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
  3. Remove the four screws on the corners of the casing.
    • Remove the four screws on the corners of the casing.
    • The volume and camera buttons may fall out
  4. Starting near the top of the casing, use the plastic opening tool to gently pry the casing open. The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
    • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
  5. Once the casing has been fully pried off of the phone, it should be easily removed by hand. The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
    • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
    • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
  6. Use the plastic opening tool to gently detach the golden strip from the logic board.
    • Use the plastic opening tool to gently detach the golden strip from the logic board.
    • The strip should detach easily with little force required.
  7. Use the plastic opening tool to pry the logic board out of the phone case from the bottom area of the phone.
    • Use the plastic opening tool to pry the logic board out of the phone case from the bottom area of the phone.
  8. Flip the logic board over and locate the three screws along the edges. Carefully unscrew the three screws to remove the panel covering the logic board.
    • Flip the logic board over and locate the three screws along the edges.
    • Carefully unscrew the three screws to remove the panel covering the logic board.
    • Be careful with the screws after unscrewing them because they are small and easy to lose.
  9. Flip the logic board back over and use the plastic opening tool to remove the metal cover on the logic board. This will not require much force, so be gentle.
    • Flip the logic board back over and use the plastic opening tool to remove the metal cover on the logic board.
    • This will not require much force, so be gentle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ashraf Nasser
126 İtibar
1 Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 103
