Ana içeriğe geç
Samsung ST150F LCD Screen Replacement
Neye ihtiyacın var
  1. Samsung ST150F LCD Screen Replacement, Outer Casing: adım 1, 3 resimden 1. Samsung ST150F LCD Screen Replacement, Outer Casing: adım 1, 3 resimden 2. Samsung ST150F LCD Screen Replacement, Outer Casing: adım 1, 3 resimden 3.
    • Remove these screws from the camera using a phillips head screwdriver.
  2. Samsung ST150F LCD Screen Replacement: adım 2, 1 resimden 1.
    • Lay the camera down on the table and remove the metal shell from the front.
  3. Samsung ST150F LCD Screen Replacement: adım 3, 1 resimden 1.
    • Wedge a spudger/flathead screwdriver inside of the shell where the screws were to pry the shell off of the back.
  4. Samsung ST150F LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove the shell the from the back of the camera.
  5. Samsung ST150F LCD Screen Replacement, LCD Screen: adım 5, 1 resimden 1.
    • Remove the Phillips head screw from the rear panel control board to reveal the LCD's connection to the motherboard.
  6. Samsung ST150F LCD Screen Replacement: adım 6, 1 resimden 1.
    • Use a spudger to flip up the light gray lever(as shown in the photo). This will release the screen so that you may pull it out.
  7. Samsung ST150F LCD Screen Replacement: adım 7, 1 resimden 1.
    • Pull the screen out of the mother board.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Nicholas Pavao
418 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Shastany Spring 2015 UMass Dartmouth, Team 2-1, Shastany Spring 2015 üyesi
UMASSD-SHASTANY-S15S2G1
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,032
