Ana içeriğe geç
Samsung ST76 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung ST76 Motherboard Replacement, Back Panel: adım 1, 3 resimden 1. Samsung ST76 Motherboard Replacement, Back Panel: adım 1, 3 resimden 2. Samsung ST76 Motherboard Replacement, Back Panel: adım 1, 3 resimden 3.
    • Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
    • Do not mix the 5 screws; they are different sizes.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung ST76 Motherboard Replacement: adım 2, 2 resimden 1. Samsung ST76 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use your fingers to pull the back cover off.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung ST76 Motherboard Replacement, Screen: adım 3, 2 resimden 1. Samsung ST76 Motherboard Replacement, Screen: adım 3, 2 resimden 2.
    • Separate the button panel to reveal the port holding the screen on.
    • Use a plastic opening tool to help with this task.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung ST76 Motherboard Replacement: adım 4, 2 resimden 1. Samsung ST76 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the yellow cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung ST76 Motherboard Replacement, Motherboard: adım 5, 3 resimden 1. Samsung ST76 Motherboard Replacement, Motherboard: adım 5, 3 resimden 2. Samsung ST76 Motherboard Replacement, Motherboard: adım 5, 3 resimden 3.
    • Remove 2 3mm screws from the metal plate covering the motherboard and lens using a Phillips #00 screw driver.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung ST76 Motherboard Replacement: adım 6, 3 resimden 1. Samsung ST76 Motherboard Replacement: adım 6, 3 resimden 2. Samsung ST76 Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove the 4 cables connecting the motherboard to the camera body.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jessica Bain
408 İtibar
2 adet Kılavuz yazıldı
Ekip
Marist, Team 1-6, Laflen Spring 2015 Marist, Team 1-6, Laflen Spring 2015 üyesi
MARS-LAFLEN-S15S1G6
2 Üyeler
8 adet Kılavuz yazıldı
3Kılavuz Yorumları
Thanks for great info. I should add that one can also clean the sensor. Sensor is circular plate with 3 screws at back of the lens. Now the camera is like new!
compand - Yanıt Paylaş
Where can you buy a replacement motherboard?
Demaree Wiitala - Yanıt Paylaş
ST76 and ST77 are very close relatives.
As it can be seen on the parts, some are marked: ”ST77”
Paul
Paul Cohen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 44
Her zaman: 1,799
