Ana içeriğe geç
Samsung ST76 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung ST76 Motherboard Replacement, Back Panel: adım 1, 3 resimden 1. Samsung ST76 Motherboard Replacement, Back Panel: adım 1, 3 resimden 2. Samsung ST76 Motherboard Replacement, Back Panel: adım 1, 3 resimden 3.
    • Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
    • Do not mix the 5 screws; they are different sizes.
  2. Samsung ST76 Motherboard Replacement: adım 2, 2 resimden 1. Samsung ST76 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use your fingers to pull the back cover off.
  3. Samsung ST76 Motherboard Replacement, Screen: adım 3, 2 resimden 1. Samsung ST76 Motherboard Replacement, Screen: adım 3, 2 resimden 2.
    • Separate the button panel to reveal the port holding the screen on.
    • Use a plastic opening tool to help with this task.
  4. Samsung ST76 Motherboard Replacement: adım 4, 2 resimden 1. Samsung ST76 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the yellow cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
  5. Samsung ST76 Motherboard Replacement, Motherboard: adım 5, 3 resimden 1. Samsung ST76 Motherboard Replacement, Motherboard: adım 5, 3 resimden 2. Samsung ST76 Motherboard Replacement, Motherboard: adım 5, 3 resimden 3.
    • Remove 2 3mm screws from the metal plate covering the motherboard and lens using a Phillips #00 screw driver.
  6. Samsung ST76 Motherboard Replacement: adım 6, 3 resimden 1. Samsung ST76 Motherboard Replacement: adım 6, 3 resimden 2. Samsung ST76 Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove the 4 cables connecting the motherboard to the camera body.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jessica Bain
393 İtibar
2 adet Kılavuz yazıldı
Ekip
Marist, Team 1-6, Laflen Spring 2015 Marist, Team 1-6, Laflen Spring 2015 üyesi
MARS-LAFLEN-S15S1G6
2 Üyeler
8 adet Kılavuz yazıldı
3 Yorum
Thanks for great info. I should add that one can also clean the sensor. Sensor is circular plate with 3 screws at back of the lens. Now the camera is like new!
compand - Yanıt
Where can you buy a replacement motherboard?
Demaree Wiitala - Yanıt
ST76 and ST77 are very close relatives.
As it can be seen on the parts, some are marked: ”ST77”
Paul
Paul Cohen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 821
