Ana içeriğe geç
Samsung Series 3 NP300E5A-A02UB AC DC Powerjack Replacement
Neye ihtiyacın var
  1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement, Battery: adım 1, 1 resimden 1.
    • Place the computer upside down, with the battery pack facing away from you.
  2. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 2, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pushing out the locks on either end then pushing the battery away from you.
  3. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement, Panel: adım 3, 1 resimden 1.
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
  4. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 4, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 4, 2 resimden 2.
    • Pull the panel towards you to release it, then lift it off the computer.
  5. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 5, 1 resimden 1.
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw next to the label “ODD."
    • Remove the three 4.5mm screws from around the memory drive nest.
  6. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 6, 1 resimden 1.
    • Using the J1 Japanese Industrial Standard screwdriver, remove the thirteen 9.5mm screws from the panel that cover the bottom of the computer.
  7. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 7, 3 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 7, 3 resimden 2. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 7, 3 resimden 3.
    • Begin removing the computer casing by prying beside the disk drive with the iFixit opening tool and the spudger, working counterclockwise.
    • Lift the panel from the computer.
  8. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement, Disc Drive: adım 8, 1 resimden 1.
    • Remove the disc drive by pulling it towards the outside of the computer.
  9. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement, Motherboard: adım 9, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement, Motherboard: adım 9, 2 resimden 2.
    • Using the J0 Japanese Industrial Standard screwdriver, remove the two 7mm screws that hold down the plug-in to the disc drive.
  10. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 10, 1 resimden 1.
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 3.5mm screw from the chip connected to the USB ports.
  11. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 11, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using the tweezers, gently pry up the chip and ports, and unthread the wire from its holders, without crimping the wires.
  12. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 12, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 12, 2 resimden 2.
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw holding down the chip next to the power prongs where the battery connects.
    • Gently pull the chip from its connector.
  13. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 13, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 13, 2 resimden 2.
    • Gently pull up the aluminum strip from the top right corner of the computer and unthread the wire from the holders using the tweezers, without crimping the wire or tearing the aluminum.
  14. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 14, 1 resimden 1.
    • Disconnect the wire screen connection from its port by pulling upwards.
  15. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 15, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 15, 2 resimden 2.
    • Gently pull up the speaker towers from either end of the computer.
  16. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 16, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 16, 2 resimden 2.
    • Using the blunt tweezers, unthread the wires that connect the motherboard to the speakers from their holders, without crimping the wires.
  17. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 17, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 17, 2 resimden 2.
    • Using the iFixit opening tool, gently pry up the plastic clasp that holds the keyboard power circuit down, and pull out the strip from the connection.
  18. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 18, 1 resimden 1.
    • Pull out the plastic cover to release the Kotl strip, then pull out the strip.
  19. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 19, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 19, 2 resimden 2.
    • Using the J0 Japanese Industrial Standard screwdriver, remove the four 4.5mm screws from the corners of the motherboard.
    • Lift the motherboard from the computer.
  20. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement, AC DC Powerjack: adım 20, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement, AC DC Powerjack: adım 20, 2 resimden 2.
    • Locate the power jack on the corner of the motherboard.
    • Locate the four connectors that hold the power jack to the motherboard.
  21. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 21, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 21, 2 resimden 2.
    • Using the Soldering Station, remove the power jack from the four connectors.
  22. Samsung Series 3 NP300E5A-A02UB AC DC Powerjack  Replacement: adım 22, 1 resimden 1.
    • Solder the new power jack in place by reattaching the four connectors.
Sonuç
After soldering the new power jack in place, reassemble your device by following these instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 1,338
