Ana içeriğe geç
Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement
Neye ihtiyacın var
  1. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Place the computer upside down, with the battery pack facing away from you.
  2. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: adım 2, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pushing out the locks on either end then pushing the battery away from you.
  3. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Panel: adım 3, 1 resimden 1.
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
  4. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: adım 4, 2 resimden 1. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: adım 4, 2 resimden 2.
    • Pull the panel towards you to release it, then lift it off the computer.
  5. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: adım 5, 1 resimden 1.
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw next to the label “ODD."
    • Remove the three 4.5mm screws from around the memory drive nest.
  6. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: adım 6, 1 resimden 1.
    • Using the J1 Japanese Industrial Standard screwdriver, remove the thirteen 9.5mm screws from the panel that cover the bottom of the computer.
  7. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: adım 7, 3 resimden 1. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: adım 7, 3 resimden 2. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: adım 7, 3 resimden 3.
    • Begin removing the computer casing by prying beside the disk drive with the iFixit opening tool and the spudger, working counterclockwise.
    • Lift the panel from the computer.
  8. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Disc Drive: adım 8, 1 resimden 1.
    • Remove the disc drive by pulling it towards the outside of the computer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 48
Her zaman: 671
