Ana içeriğe geç
Samsung Series 5 3G Chromebook Battery Replacement
Neye ihtiyacın var
  1. Samsung Series 5 3G Chromebook Battery Replacement, Back Cover: adım 1, 2 resimden 1. Samsung Series 5 3G Chromebook Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel using your fingernails.
    • Remove all the seven screws from the bottom panel.
  2. Samsung Series 5 3G Chromebook Battery Replacement: adım 2, 2 resimden 1. Samsung Series 5 3G Chromebook Battery Replacement: adım 2, 2 resimden 2.
    • Loosen the back cover panel using a spudger.
  3. Samsung Series 5 3G Chromebook Battery Replacement: adım 3, 2 resimden 1. Samsung Series 5 3G Chromebook Battery Replacement: adım 3, 2 resimden 2.
    • Once you work your way around, you can remove the panel.
  4. Samsung Series 5 3G Chromebook Battery Replacement, Battery: adım 4, 3 resimden 1. Samsung Series 5 3G Chromebook Battery Replacement, Battery: adım 4, 3 resimden 2. Samsung Series 5 3G Chromebook Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Remove three Phillips screws from the battery.
    • Disconnect the battery from the motherboard.
    • Lift the battery up and away from the laptop to remove it.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Helder Avelino
938 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
i want the chromebook battery
Christopher Jorgensen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 19,224
