Ana içeriğe geç
Samsung Series 5 UltraTouch Battery Replacement
Neye ihtiyacın var
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: adım 1, 2 resimden 1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: adım 1, 2 resimden 2.
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: adım 2, 2 resimden 1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: adım 2, 2 resimden 2.
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: adım 3, 2 resimden 1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: adım 3, 2 resimden 2.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: adım 4, 2 resimden 1. Samsung Series 5 UltraTouch Battery Replacement: adım 4, 2 resimden 2.
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: adım 5, 1 resimden 1.
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: adım 6, 1 resimden 1.
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: adım 7, 1 resimden 1.
    • Remove the battery from the laptop.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Timothy
1.579 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-3, Watkins Winter 2015 USF Tampa, Team 16-3, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S16G3
4 Üyeler
2 Yorum
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Yanıt
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 26,770
