Ana içeriğe geç
Samsung Series 5 Ultrabook Hard Drive Replacement
Neye ihtiyacın var
  1. Samsung Series 5 Ultrabook Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Take out the four 6.7 mm screws that hold the hard drive and the mounting plate in place.
    • Keep these screws separate as they are a different size than the cover's screw.
  2. Samsung Series 5 Ultrabook Hard Drive Replacement: adım 2, 2 resimden 1. Samsung Series 5 Ultrabook Hard Drive Replacement: adım 2, 2 resimden 2.
    • Remove the hard drive from its location.
    • Unplug the hard drive from the mother board.
Sonuç
To reassemble the device, follow the steps in reverse order.
8 farklı kişi bu kılavuzu tamamladı.
Timothy
1.579 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-3, Watkins Winter 2015 USF Tampa, Team 16-3, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S16G3
4 Üyeler
5 Yorum
New bios update does not allow the SSD to be used, any idea how this is fixable ?
sergeybirioukov - Yanıt
I am pleased to report that using these instructions on June 2019 I have successfully replaced the hdd with a ssd on Samsung Series 5 model NP520U4C-A01UB. Used samsung’s official disk copy utility. It first recreates exactly the same partition size but I was able to shrink the windows partition using linux’s gparted then install ubuntu 19.04 from a usb thumbdrive. For installing from usb thumbdrive it seems uefi and fastboot should be disabled and the boot order should be placed where the usb is the first to boot (watch out for the boot order changing with any install attempts). Thanks for posting this guide; the ssd makes a huge difference in performance :)
Nathaniel Sutton - Yanıt
During removal of the hard drive, i accidentally pulled the cable out of it’s connection to the motherboard.
At first, i thought i damaged it as it looked like I pulled the ribbon cable out of it’s connector that also fell out of the motherboard.
When looking at replacement connectors, it appears that it is not terminated with a connector - just a flat ribbon.
Has anyone pulled their cable out of the motherboard connector, and is there any trick to getting it back in?
markallen3 - Yanıt
best strategy: carefully unlock the ribbon cable motherboards connector by its upper part 90 degrees into an upright position. Then pull out the ribbon cable completely by removing the harddisk tray assembly including the cable harness. Then unplug the connector on the hdd side. This procedure does less stress to the sensible ribbon cable.
Claus D. aus F. am M. - Yanıt
Please am looking for samsung NP540U3C hdd connector fiber…
Mwoosa Ebraheem - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 15,503
