Giriş
use this guide in the case that you need to remove the screen of the Samsung Series 7XE700T1A for any reason
Neye ihtiyacın var
Wedge the opening tools inside the side of the device, and move it around the parameter until you have loosened the adhesive holding it together.
There is some circuitry that needs to be removed that is keeping the screen and tablet together.
The main circuitry that is connected to the screen and tablet together is the skinny one located in the middle.
Using your hands, pull the circuit out from its position to help loosen the connection.
