Giriş
Remove if you have damaged the USB , AUX , or HDMI port.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
Locate the AUX and USB port on the left side of the laptop.
Neredeyse bitti!
To reassemble your device, follow these instructions in reverse order. If the replacement does not fix your problem, you may have a motherboard problem that will require a software dignostic.
Sonuç
