Ana içeriğe geç
Samsung Series 9 NP900X3C-A02US Touch Pad Replacement
Neye ihtiyacın var
  1. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement, Touch Pad: adım 1, 1 resimden 1.
    • Shut down the laptop.
    • Power off the laptop by navigating the window icon on the bottom left and clicking on the power followed by shutdown.
  2. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: adım 2, 2 resimden 1. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: adım 2, 2 resimden 2.
    • Remove the back cover of the laptop by using a Phillips #00 screwdriver to remove ten 2 mm screws.
    • Pry out the bottom panel on all sides using a prying tool.
  3. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: adım 3, 3 resimden 1. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: adım 3, 3 resimden 2. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: adım 3, 3 resimden 3.
    • Unscrew the internal battery and disconnect it from the motherboard.
    • Remove all the cables, tapes by using the tools such as plastic spudgers.
    • Look for the ribbon cable connection and by using the spudger to pull up the clip and unlock the ribbon cable.
  4. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: adım 4, 2 resimden 1. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: adım 4, 2 resimden 2.
    • Peel out any tapes holding the touchpad carefully.
  5. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: adım 5, 2 resimden 1. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: adım 5, 2 resimden 2.
    • By using the prying tool unstick and detach the module.
  6. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: adım 6, 2 resimden 1. Samsung Series 9 NP900X3C-A02US Touch Pad Replacement: adım 6, 2 resimden 2.
    • Remove four 0.1mm screws using a Phillips #00 Screwdriver from the laptop.
    • Open the laptop a little bit to create space to drop the touchpad module by pushing it gently downwards.
    • After taking out the touchpad clean it especially at the edges and the corners by using rubbing alcohol and microfiber cloth.
Sonuç
Ghaniyah Gul
391 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team A-2, Gonzalez Spring 2023 Gateway, Team A-2, Gonzalez Spring 2023 üyesi
GCC-GONZALEZ-S23SAG2
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 164
