Giriş
In this guide, we will be showing you how to replace the display on the Samsung Series 9 NP900X4D-A03US. We begin by removing the adhesive frame from the display, unscrewing the screws holding the display in place, and detaching the cable that keeps it intact.
Neye ihtiyacın var
Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
Use an iFixit opening tool to carefully remove the back panel from the laptop.
Using tweezers, gently remove the adhesive surrounding the cover. At the same time, gently pry the cover off of the display using an iFixit opening tool.
Gently place the cover to the left, as a wire is still attached.
Bir başkası bu kılavuzu tamamladı.
3 Yorum
Good day
Where can I buy the screen?
My laptop model number is NP900X4D-A01ZA
Your assistance will be highly appreciated
Kind regards
is not easy to get that screen i think it needs a special screen
How Can I get that screen or any other related Screen ?
