Ana içeriğe geç
Samsung Series 9 NP900X4D-A03US RAM Replacement
Neye ihtiyacın var
  1. Samsung Series 9 NP900X4D-A03US RAM Replacement, Battery: adım 1, 2 resimden 1. Samsung Series 9 NP900X4D-A03US RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
    • Use an iFixit opening tool to carefully remove the back panel from the laptop.
  2. Samsung Series 9 NP900X4D-A03US RAM Replacement: adım 2, 1 resimden 1.
    • Remove the seven 0.5 mm Phillips #00 screws.
  3. Samsung Series 9 NP900X4D-A03US RAM Replacement: adım 3, 3 resimden 1. Samsung Series 9 NP900X4D-A03US RAM Replacement: adım 3, 3 resimden 2. Samsung Series 9 NP900X4D-A03US RAM Replacement: adım 3, 3 resimden 3.
    • Lightly place some pressure into the highlighted cavity on the battery's outlet plug with a spudger.
    • Carefully remove the wires from the outlet plug.
    • Now you will be able to remove the battery from its place.
  4. Samsung Series 9 NP900X4D-A03US RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Move aside the two metal retaining clips.
    • Pull the RAM stick out to remove it.
Sonuç
Aimee Young
293 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G4, Cardinal Spring 2019 UW Tacoma, Team S1-G4, Cardinal Spring 2019 üyesi
UWT-CARDINAL-S19S1G4
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 742
