Ana içeriğe geç
Samsung Series 9 NP900X4D-A03US WiFi Card Replacement
Neye ihtiyacın var
  1. Samsung Series 9 NP900X4D-A03US WiFi Card Replacement, WiFi Card: adım 1, 1 resimden 1.
    • Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
    • Remove the back panel of the laptop.
  2. Samsung Series 9 NP900X4D-A03US WiFi Card Replacement: adım 2, 1 resimden 1.
    • Locate the WiFi card once you've removed the back panel.
  3. Samsung Series 9 NP900X4D-A03US WiFi Card Replacement: adım 3, 1 resimden 1.
    • Remove the two 2.5 mm Phillips #00 screws.
  4. Samsung Series 9 NP900X4D-A03US WiFi Card Replacement: adım 4, 1 resimden 1.
    • Remove the two wires connected to the WiFi card using a nylon spudger.
  5. Samsung Series 9 NP900X4D-A03US WiFi Card Replacement: adım 5, 1 resimden 1.
    • Gently lift up the WiFi card to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aimee Young
293 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G4, Cardinal Spring 2019 UW Tacoma, Team S1-G4, Cardinal Spring 2019 üyesi
UWT-CARDINAL-S19S1G4
3 Üyeler
3 adet Kılavuz yazıldı
3 Yorum
Does Intel AC-7260 work in Samsung NP900X4D for faster WiFi Speed , The N-6235 is slow!
Ben - Yanıt
It does. I just added the AC-7620 to my NP900X4C. And it works perfectly! Speed difference is huge. Went from 70 to 80 mbps to 250 mbsp on a 300 mbps connection. USB dongles didn't make much of a difference. It you have an older 900x give this a try.
AC-7620 WiFi card on Amazon
Heron - Yanıt
Also if you do a clean install of Windows 10, the bluetooth driver doesn't install automatically. Here was the last version released by Intel.
Latest Intel Bluetooth Driver
Heron -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,073
