Ana içeriğe geç
Samsung SmartCam HD Speaker Replacement
Neye ihtiyacın var
  1. Samsung SmartCam HD Speaker Replacement, Speaker: adım 1, 3 resimden 1. Samsung SmartCam HD Speaker Replacement, Speaker: adım 1, 3 resimden 2. Samsung SmartCam HD Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Remove the mount.
    • Use the mount replacement guide if necessary to take the mount off.
  2. Samsung SmartCam HD Speaker Replacement: adım 2, 2 resimden 1. Samsung SmartCam HD Speaker Replacement: adım 2, 2 resimden 2.
    • Unscrew the screw next to the mount holder.
  3. Samsung SmartCam HD Speaker Replacement: adım 3, 3 resimden 1. Samsung SmartCam HD Speaker Replacement: adım 3, 3 resimden 2. Samsung SmartCam HD Speaker Replacement: adım 3, 3 resimden 3.
    • At the bottom of the SmartCam there is a tab that you can stick a spudger r in.
    • Once the spudger is in, gently pry it open.
    • Work your way around the SmartCam with the spudger loosing 8 clips.
    • Buttons may fall out, but can be reinserted easily.
  4. Samsung SmartCam HD Speaker Replacement: adım 4, 2 resimden 1. Samsung SmartCam HD Speaker Replacement: adım 4, 2 resimden 2.
    • Gently remover the cover.
    • Beware of the wires connected to the camera.
  5. Samsung SmartCam HD Speaker Replacement: adım 5, 3 resimden 1. Samsung SmartCam HD Speaker Replacement: adım 5, 3 resimden 2. Samsung SmartCam HD Speaker Replacement: adım 5, 3 resimden 3.
    • The speaker should be attached to the cover with red and black wires going to the main board.
    • Unscrew the two screws holding the speaker in place.
  6. Samsung SmartCam HD Speaker Replacement: adım 6, 3 resimden 1. Samsung SmartCam HD Speaker Replacement: adım 6, 3 resimden 2. Samsung SmartCam HD Speaker Replacement: adım 6, 3 resimden 3.
    • Gently take the speaker out of the cover.
    • Take out the red and black wires from a small plug-in on the main board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Pranab Baidya
104 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G1, Liner Summer 2017 UW Tacoma, Team S1-G1, Liner Summer 2017 üyesi
UWT-LINER-SU17S1G1
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
You mind giving speaker part number. I have the Samsung camera with the smaller speaker. Any ideas
frank scalise - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 575
