Giriş
This guide outlines a procedure for completely removing and replacing a non-functioning Ethernet port on the motherboard of the Samsung SmartThings Hub.
Neye ihtiyacın var
To open your device, gently slide the grey bottom cover in the direction of the arrow as shown.
Place the motherboard on a clean, flat surface.
Preheat your soldering iron. The Ethernet port has fourteen points of connection to the motherboard (pictured below). Using your soldering iron, apply heat to each solder joint in turn while pulling the Ethernet port away from the board.
Bir başkası bu kılavuzu tamamladı.
