Ana içeriğe geç
Samsung Solstice Battery Replacement
Neye ihtiyacın var
    1. Samsung Solstice Battery Replacement, Removing the back cover: adım 1, 3 resimden 1. Samsung Solstice Battery Replacement, Removing the back cover: adım 1, 3 resimden 2. Samsung Solstice Battery Replacement, Removing the back cover: adım 1, 3 resimden 3.
      • Gently slide the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
      • Set the cover off to the side once you have removed it.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Solstice Battery Replacement, Removing the battery: adım 2, 3 resimden 1. Samsung Solstice Battery Replacement, Removing the battery: adım 2, 3 resimden 2. Samsung Solstice Battery Replacement, Removing the battery: adım 2, 3 resimden 3.
      • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
      • Wedge a plastic opening tool in between the rear end of the battery and the plastic frame.
      • Pry the battery up out of its recess and away from the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Colton Glyder
301 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 25
Her zaman: 662
