Ana içeriğe geç
Samsung Spex SCH-R210 Battery Replacement
  1. Samsung Spex SCH-R210 Battery Replacement, Back Cover: adım 1, 3 resimden 1. Samsung Spex SCH-R210 Battery Replacement, Back Cover: adım 1, 3 resimden 2. Samsung Spex SCH-R210 Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung Spex SCH-R210 Battery Replacement, Battery: adım 2, 1 resimden 1.
    • Locate the access notch at the end of the battery compartment.
  3. Samsung Spex SCH-R210 Battery Replacement: adım 3, 1 resimden 1.
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
Sonuç
Austin
201 İtibar
2 adet Kılavuz yazıldı
Ekip
WRI115, Team 1-4, Ruszkiewicz Spring 2013 WRI115, Team 1-4, Ruszkiewicz Spring 2013 üyesi
WRI115-RUSZKIEWICZ-S13S1G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 313
