Ana içeriğe geç
Samsung Star Touch Screen Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Star Touch Screen Replacement, Touch Screen: adım 1, 3 resimden 1. Samsung Star Touch Screen Replacement, Touch Screen: adım 1, 3 resimden 2. Samsung Star Touch Screen Replacement, Touch Screen: adım 1, 3 resimden 3.
    • Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws.
  2. Samsung Star Touch Screen Replacement: adım 2, 3 resimden 1. Samsung Star Touch Screen Replacement: adım 2, 3 resimden 2. Samsung Star Touch Screen Replacement: adım 2, 3 resimden 3.
    • After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board.
  3. Samsung Star Touch Screen Replacement: adım 3, 3 resimden 1. Samsung Star Touch Screen Replacement: adım 3, 3 resimden 2. Samsung Star Touch Screen Replacement: adım 3, 3 resimden 3.
    • Unstuck camera keys and remove the middle bezel.
  4. Samsung Star Touch Screen Replacement: adım 4, 2 resimden 1. Samsung Star Touch Screen Replacement: adım 4, 2 resimden 2.
    • Disconnect the flex-cable from touch screen and the flex-cable from the small keyboard down.
  5. Samsung Star Touch Screen Replacement: adım 5, 3 resimden 1. Samsung Star Touch Screen Replacement: adım 5, 3 resimden 2. Samsung Star Touch Screen Replacement: adım 5, 3 resimden 3.
    • On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation.
  6. Samsung Star Touch Screen Replacement: adım 6, 2 resimden 1. Samsung Star Touch Screen Replacement: adım 6, 2 resimden 2.
    • Now is easy to remove the touch screen.
  7. Samsung Star Touch Screen Replacement: adım 7, 3 resimden 1. Samsung Star Touch Screen Replacement: adım 7, 3 resimden 2. Samsung Star Touch Screen Replacement: adım 7, 3 resimden 3.
    • Install new touch screen and assembly the phone.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
ZFix
191.308 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.532 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 3,825
