Ana içeriğe geç
Samsung Stratosphere Front Camera Replacement
Neye ihtiyacın var
  1. Samsung Stratosphere Front Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Stratosphere Front Camera Replacement: adım 2, 1 resimden 1.
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Stratosphere Front Camera Replacement, Motherboard: adım 3, 1 resimden 1.
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Stratosphere Front Camera Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Stratosphere Front Camera Replacement: adım 5, 1 resimden 1.
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Stratosphere Front Camera Replacement: adım 6, 1 resimden 1.
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Stratosphere Front Camera Replacement: adım 7, 2 resimden 1. Samsung Stratosphere Front Camera Replacement: adım 7, 2 resimden 2.
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Stratosphere Front Camera Replacement: adım 8, 1 resimden 1.
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Stratosphere Front Camera Replacement, Front Camera: adım 9, 1 resimden 1.
    • Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
    • Pry the keyboard away from the casing with the plastic opening tool.
    • The keyboard should come off with almost no force at all.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Stratosphere Front Camera Replacement: adım 10, 1 resimden 1.
    • Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Stratosphere Front Camera Replacement: adım 11, 1 resimden 1.
    • Use the plastic opening tool to carefully loosen the golden metal plate.
    • The golden metal plate is stuck to the rear panel with a strong adhesive, so a moderate amount of force may be needed.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Stratosphere Front Camera Replacement: adım 12, 1 resimden 1.
    • Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
    • Carefully take off the keyboard casing with your fingers.
    • The golden metal plate should fit through the wide slot of the casing.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Stratosphere Front Camera Replacement: adım 13, 1 resimden 1.
    • Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
    • The metal plate is attached to springs that offer a small amount of resistance, so it will snap into place.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Stratosphere Front Camera Replacement: adım 14, 1 resimden 1.
    • Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Stratosphere Front Camera Replacement: adım 15, 2 resimden 1. Samsung Stratosphere Front Camera Replacement: adım 15, 2 resimden 2.
    • Insert the plastic opening tool into the groove at the top of the rear panel.
    • Firmly slide the plastic opening tool all around the rear panel. The panel will audibly snap as it comes apart.
    • These 2 pieces are attached well, so a significant amount of force is needed to separate them.
    FixBot'a Sor
    Yorum Ekle
  16. Samsung Stratosphere Front Camera Replacement: adım 16, 1 resimden 1.
    • Lift the flex cable and position it so the part containing the metal plate can come free.
    • Pull the part containing the metal plate away from the rest of the rear panel.
    FixBot'a Sor
    Yorum Ekle
  17. Samsung Stratosphere Front Camera Replacement: adım 17, 2 resimden 1. Samsung Stratosphere Front Camera Replacement: adım 17, 2 resimden 2.
    • Use tweezers to loosen the front-facing camera from the plastic casing.
    • Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ryan
375 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-32, Amido Fall 2013 Cal Poly, Team 11-32, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S11G32
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 818
