Ana içeriğe geç
Samsung Stratosphere Rear Camera Replacement
Neye ihtiyacın var
  1. Samsung Stratosphere Rear Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Stratosphere Rear Camera Replacement: adım 2, 1 resimden 1.
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Stratosphere Rear Camera Replacement, Motherboard: adım 3, 1 resimden 1.
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Stratosphere Rear Camera Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Stratosphere Rear Camera Replacement: adım 5, 1 resimden 1.
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Stratosphere Rear Camera Replacement: adım 6, 1 resimden 1.
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Stratosphere Rear Camera Replacement: adım 7, 2 resimden 1. Samsung Stratosphere Rear Camera Replacement: adım 7, 2 resimden 2.
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Stratosphere Rear Camera Replacement: adım 8, 1 resimden 1.
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Stratosphere Rear Camera Replacement, Rear Camera: adım 9, 1 resimden 1.
    • Gently pull the camera to the left while keeping it as close to the motherboard as possible.
    • The metal foil connector attached to the camera should slide out of the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Ryan
375 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-32, Amido Fall 2013 Cal Poly, Team 11-32, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S11G32
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 1,002
