Ana içeriğe geç
Samsung T139 Camera Lens Replacement
Neye ihtiyacın var
  1. Samsung T139 Camera Lens Replacement, Remove Back Cover: adım 1, 3 resimden 1. Samsung T139 Camera Lens Replacement, Remove Back Cover: adım 1, 3 resimden 2. Samsung T139 Camera Lens Replacement, Remove Back Cover: adım 1, 3 resimden 3.
    • Power off your phone before beginning disassembly
    • Apply pressure to the back cover and slide towards the base
    FixBot'a Sor
    Yorum Ekle
  2. Samsung T139 Camera Lens Replacement, Remove Battery: adım 2, 2 resimden 1. Samsung T139 Camera Lens Replacement, Remove Battery: adım 2, 2 resimden 2.
    • With a plastic opening tool, lift and remove the battery
    FixBot'a Sor
    Yorum Ekle
  3. Samsung T139 Camera Lens Replacement, Remove Screw Stickers: adım 3, 2 resimden 1. Samsung T139 Camera Lens Replacement, Remove Screw Stickers: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using the tweezers, remove the two rubber soles that cover the panel screws
    FixBot'a Sor
    Yorum Ekle
  4. Samsung T139 Camera Lens Replacement, Remove Screws: adım 4, 2 resimden 1. Samsung T139 Camera Lens Replacement, Remove Screws: adım 4, 2 resimden 2.
    • Remove two Phillips 1.0mm #0 screws
    FixBot'a Sor
    Yorum Ekle
  5. Samsung T139 Camera Lens Replacement, Remove Face Plate: adım 5, 3 resimden 1. Samsung T139 Camera Lens Replacement, Remove Face Plate: adım 5, 3 resimden 2. Samsung T139 Camera Lens Replacement, Remove Face Plate: adım 5, 3 resimden 3.
    • With the plastic opening tool, work around the face plate until it pops off
    FixBot'a Sor
    Yorum Ekle
  6. Samsung T139 Camera Lens Replacement, Remove Camera Lens: adım 6, 2 resimden 1. Samsung T139 Camera Lens Replacement, Remove Camera Lens: adım 6, 2 resimden 2.
    • Apply pressure to the lens, pushing it out the back
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Reagan May
588 İtibar
5 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-1, Lauer Fall 2014 Michigan Tech, Team 1-1, Lauer Fall 2014 üyesi
MTU-LAUER-F14S1G1
3 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 466
