Ana içeriğe geç
Samsung TFT Color YP-T7J The Battery Replacement
Neye ihtiyacın var
  1. Samsung TFT Color YP-T7J The Battery Replacement, The Back Cover: adım 1, 2 resimden 1. Samsung TFT Color YP-T7J The Battery Replacement, The Back Cover: adım 1, 2 resimden 2.
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Samsung TFT Color YP-T7J The Battery Replacement: adım 2, 2 resimden 1. Samsung TFT Color YP-T7J The Battery Replacement: adım 2, 2 resimden 2.
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Samsung TFT Color YP-T7J The Battery Replacement: adım 3, 3 resimden 1. Samsung TFT Color YP-T7J The Battery Replacement: adım 3, 3 resimden 2. Samsung TFT Color YP-T7J The Battery Replacement: adım 3, 3 resimden 3.
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Samsung TFT Color YP-T7J The Battery Replacement, The Battery: adım 4, 2 resimden 1. Samsung TFT Color YP-T7J The Battery Replacement, The Battery: adım 4, 2 resimden 2.
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Samsung TFT Color YP-T7J The Battery Replacement: adım 5, 2 resimden 1. Samsung TFT Color YP-T7J The Battery Replacement: adım 5, 2 resimden 2.
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dylan Peters
409 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-8, Benson Fall 2013 Clemson, Team 14-8, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G8
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Nice instructions. Any idea where I can purchase a new battery that will fit?
grgermain - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 1,863
